ONLYoffice™
ONLYoffice™
Postby cloudhosting.space » Sun Jun 04, 2017 12:15 am
Debian 8 Jessie
Community Server latest version install (no docker)
Server was built fresh yesterday using the ONLYoffice installation procedure on the web.
certbot certonly --webroot -w /var/www/onlyoffice -d yourdomain.com
UnicodeEncodeError: 'ascii' codec can't encode character u'\ufeff' in position 208: ordinal not in range(128)
I think it is because of this:
I guess the strange character at the end is something like the trademark character ONLYOFFICE™
Document Server does not have this strange character.
I also noticed some special characters in the help text in the Settings not displaying properly. May be a server issue. Document Server works fine using certbot HTTPS.
cloudhosting.space
Re: ONLYoffice™
Postby Maxim » Mon Jun 05, 2017 11:30 am
Hello cloudhosting.space!
Specify please what instruction did you follow to install Community Server?
Re: ONLYoffice™
Postby cloudhosting.space » Mon Jun 05, 2017 12:20 pm
Maxim,
The problem was related to "/etc/nginx/available-sites/onlyoffice" modified for HTTPS.
https://helpcenter.onlyoffice.com/serve ... https.aspx
The instructions suggest using a template from here:
https://github.com/ONLYOFFICE/Docker-Co ... office-ssl
It requires serious modifications and in my case created a bit of a puzzle to solve:
The following causes error 403 or 404:
location ~ ^/.well-known {
allow all;
include /etc/nginx/includes/onlyoffice-communityserver-*.conf;
Reversing the order of the exact same instructions is what was required to make it work:
allow all;
Case closed; thank you for your help.
cloudhosting.space
