Error when trying to connect Nextcloud with Document Server
Postby Koval88 » Wed May 31, 2017 6:37 pm
I'm having trouble integrating onlyoffice document server running on ubuntu 16 to the nextcloud server also running on a separate ubuntu 16.
I have self-assigned certificates on both, nextcloud and onlyoffice document server.
I've had trouble with docker and with the install without a docker.
Currently, I've set up my document server using the following: http://helpcenter.onlyoffice.com/server ... ation.aspx
I've setup SSL certificate using the following guide: http://helpcenter.onlyoffice.com/server ... https.aspx
When I go to onlyoffice.mydomain.com my server is running "Document Server is running"
However when I apply the Document Server FQDN I get "Error when trying to connect".
Both, nextcloud and document server use FQDN and are running over HTTPS. It works fine when I have Nextcloud over HTTP and document server without using SSL, but when I do this switch it doesn't seem to be working.
I'm looking forward to hearing solutions.
Thank you!
Here is the config file for onlyoffice: /etc/nginx/conf.d/onlyoffice-documentserver.conf
include /etc/nginx/includes/onlyoffice-http.conf;
## Normal HTTP host
server {
  listen 0.0.0.0:80;
  listen [::]:80 default_server;
  server_name onlyoffice.mydomain.com;
  server_tokens off;
  ## Redirects all traffic to the HTTPS host
  root /nowhere; ## root doesn't have to be a valid path since we are redirecting
  rewrite ^ https://$host$request_uri? permanent;
#HTTP host for internal services
server {
  listen 127.0.0.1:80;
  listen [::1]:80;
  server_name localhost;
  server_tokens off;
  include /etc/nginx/includes/onlyoffice-documentserver-common.conf;
  include /etc/nginx/includes/onlyoffice-documentserver-docservice.conf;
## HTTPS host
server {
  listen 0.0.0.0:443 ssl;
  listen [::]:443 ssl default_server;
  server_tokens off;
  root /usr/share/nginx/html;
  ## Strong SSL Security
  ## https://raymii.org/s/tutorials/Strong_SSL_Security_On_nginx.html
  ssl on;
  ssl_certificate /app/onlyoffice/CommunityServer/data/certs/onlyoffice.crt;
  ssl_certificate_key /app/onlyoffice/CommunityServer/data/certs/onlyoffice.key;
  # ssl_verify_client {{SSL_VERIFY_CLIENT}};
  # ssl_client_certificate {{CA_CERTIFICATES_PATH}};
  ssl_ciphers "ECDHE-RSA-AES128-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA128:DHE-RSA-AES128-GCM-SHA384:DHE-RSA-AES128-GCM-SHA128:ECDHE-RSA-AES128-SHA384:ECDHE-RSA-AES128-SHA128:ECDHE-RSA-AES128-SHA:ECDHE-RSA-AES128-SHA:DHE-RSA-AES128-SHA128:DHE-RSA-AES128-SHA128:DHE-RSA-AES128-SHA:DHE-RSA-AES128-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA384:AES128-GCM-SHA128:AES128-SHA128:AES128-SHA128:AES128-SHA:AES128-SHA:DES-CBC3-SHA:HIGH:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4";
  ssl_protocols  TLSv1 TLSv1.1 TLSv1.2;
  ssl_session_cache  builtin:1000  shared:SSL:10m;
  ssl_prefer_server_ciphers   on;
  add_header Strict-Transport-Security max-age=31536000;
  # add_header X-Frame-Options SAMEORIGIN;
  add_header X-Content-Type-Options nosniff;
  ## [Optional] If your certficate has OCSP, enable OCSP stapling to reduce the overhead and latency of running SSL.
  ## Replace with your ssl_trusted_certificate. For more info see:
  ## - https://medium.com/devops-programming/4445f4862461
  ## - https://www.ruby-forum.com/topic/4419319
  ## - https://www.digitalocean.com/community/tutorials/how-to-configure-ocsp-stapling-on-apache-and-nginx
  # ssl_stapling on;
  # ssl_stapling_verify on;
  # ssl_trusted_certificate /etc/nginx/ssl/stapling.trusted.crt;
  # resolver 208.67.222.222 208.67.222.220 valid=300s; # Can change to your DNS resolver if desired
  # resolver_timeout 10s;
  ## [Optional] Generate a stronger DHE parameter:
  ##   cd /etc/ssl/certs
  ##   sudo openssl dhparam -out dhparam.pem 4096
  ssl_dhparam /app/onlyoffice/CommunityServer/data/certs/dhparam.pem;
  include /etc/nginx/includes/onlyoffice-documentserver-*.conf;
Koval88
Re: Error when trying to connect Nextcloud with Document Ser
Postby Maxim » Thu Jun 01, 2017 9:09 am
Hello Koval88!
We need to analyze your logs of NC and DS /app/onlyoffice/DocumentServer/logs - for Docker; /var/log/onlyoffice - for Linux.
Also specify please did you run NC server over HTTPS and what do you mean by "However when I apply the Document Server FQDN I get "Error when trying to connect"?
Postby cloudhosting.space » Fri Jun 02, 2017 2:24 pm
The Server URL you enter in Document Server to connect to your Nextcloud office is slightly different as you need to point to the WebDAV interface.
If your Nextcloud server is running on:
'https://yourdomain.com'
simply use:
'https://yourdomain.com/remote.php/webdav'
inside the Document Server popup window to connect to a Nextcloud server.
Regards,
cloudhosting.space
