Centos 7 install failed
Postby svennd » Tue May 16, 2017 1:33 pm
After following these docs, I end up with this error :
Thank you for choosing ONLYOFFICE!
Something went wrong during installation
Make sure that you have followed the installation instructions
Any questions?
Explore ONLYOFFICE™ Document Server API Documentation
or visit our developers forum.
when I integrate it with seafile the interface loads, but keeps on loading. Where should I first look ?
svennd
Re: Centos 7 install failed
Postby Maxim » Wed May 17, 2017 8:03 am
Hello svennd!
Please use this instruction to install Integration Edition.
The instruction you used is intended to work with Community Server.
Before installation make sure that you uninstall all components you installed following instruction you used.
Also if you still face issues with it you can install Docker version which we recommend
Postby svennd » Wed May 17, 2017 10:07 am
Ah, so in that case only a licensed (=payed) option is available ? Thanks for helping :)
svennd
Postby Maxim » Wed May 17, 2017 11:37 am
Svennd Document Server should work anyway! It doesn't matter Integration Edition or not.
