Document Server - HTTPS Document Download Failed
Postby jp001 » Fri May 12, 2017 2:36 am
Hi all,
I have installed Nextcloud and Onlyoffice using http protocol internally and everything is working perfectly. I did another install of both with https for external access and Onlyoffice will connect, try to open a doc but gives out and error stating
"Download Failed" Press "OK to return to document list.
All web URL's connect fine to both. I'm running Onlyoffice and Nextloud on the same sever with different ports for each. Is this a bad idea should I be running Onlyoffice on another server? It's been doing my head in for days! Any help or ideas would be great.
Nextcloud https :8443
Onlyoffice https :444
jp001
Re: Document Server - HTTPS Document Download Failed
Postby Maxim » Fri May 12, 2017 1:24 pm
Hello jp001!
See here. There is a wrong request from DC to NC to storage the file.
How? What instruction did you follow?
in that case you need to configure reverse proxy.
