SpellCheck failing to start
Postby jtinsley » Thu Apr 06, 2017 2:57 pm
The SpellCheck server is crash-looping / failing to start via supervisor, on a deb-installed package, on Debian Jessie:
log
Error: The module '/var/www/onlyoffice/documentserver/server/SpellChecker/node_modules/nodehun/build/Release/nodehun.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 48. This version of Node.js requires
NODE_MODULE_VERSION 51. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or`npm install`).
at Object.Module._extensions..node (module.js:598:18)
at Module.load (module.js:488:32)
at tryModuleLoad (module.js:447:12)
at Function.Module._load (module.js:439:3)
at Module.require (module.js:498:17)
at require (internal/module.js:20:19)
at Object.<anonymous> (/var/www/onlyoffice/documentserver/server/SpellChecker/sources/spellCheck.js:11:12)
at Module._compile (module.js:571:32)
at Object.Module._extensions..js (module.js:580:10)
[2017-04-06 14:21:22.911] [WARN] nodeJS - worker 19256 died. restart...
Also, documentation mentions restarting it via systemd, but the system isn't running the daemons via systemd.
Finally, forums are using http, modern firefox & chrome are not happy about this!
jtinsley
Re: SpellCheck failing to start
Postby Maxim » Tue Apr 11, 2017 9:43 am
Hello jtinsley!
There is a problem with node.js version you're using.
We advice you to install Node.js v6.10.2.
Postby jtinsley » Tue Apr 18, 2017 10:47 am
Downgraded node.js from 7 -> 6 now, and it's started ok, thanks :)
jtinsley
Postby Maxim » Tue Apr 18, 2017 11:17 am
Hello jtinsley!
You're welcome!
