CommunityServer 8.9.1.340 installation issue on WS 2008R2
Postby koksalbasar » Fri Feb 10, 2017 8:15 pm
I've tried to install OOCS 8.9.1.340 on my WS2008R2 VPS. Everything seems ok while installation progress. Wizard is connecting MYSQL database, after that, an OnlyOffice icon is appearing on the desktop. When the wizard shows "IIS Configuration" message the icon is disappearing. The wizard can not continue after the "Installing IIS URL Rewrite Module 2" message.
The last message is on the screen is "The Onlyoffice setup wizard ended prematurely". I checked out log file. I found 4 failed notes. I think of that is not so important.
I could not add the original log file because of the file limit (Even the zip file greater than the size limit.). I created a short form of the file, 4 failed notes and the last part of the file. I hope it will help you.
PS: I installed v8.7.1.290 first of all . Every thing was perfect except documents. I've tried to install Document server v3.0 but it failed also.
Thanks for your support
OnlyOffice_Error_Log_short.zip
(15.4 KiB) Downloaded 59 times
koksalbasar
Re: CommunityServer 8.9.1.340 installation issue on WS 2008R
Postby Maxim » Mon Feb 13, 2017 8:34 am
Hello koksalbasar!
Please specify what error(s) did you notice while installation of Document Server?
Postby koksalbasar » Tue Feb 14, 2017 11:05 pm
Hi Maxim,
I've tried to install ONLYOFFICE_DocumentServer_Win-install.v3.0.exe
When I try the fresh install the following general error message have shown by the installer.
This message had no extra information. The log file finishes with these lines.
Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action EnableRouting, location: C:\Users\ADMINI~1\AppData\Local\Temp\4\MSI69F.tmp, command: /RunAsAdmin /HideWindow "C:\Windows\SysWOW64\inetsrv\appcmd.exe" set config -section:system.webServer/proxy /enabled:true
MSI (c) (4C:A8) [01:18:52:067]: Product: ONLYOFFICE DocumentServer -- Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action EnableRouting, location: C:\Users\ADMINI~1\AppData\Local\Temp\4\MSI69F.tmp, command: /RunAsAdmin /HideWindow "C:\Windows\SysWOW64\inetsrv\appcmd.exe" set config -section:system.webServer/proxy /enabled:true
Action ended 1:18:52: EnableRouting. Return value 3.
MSI (c) (4C:A8) [01:18:52:067]: Doing action: FatalError
Action 1:18:52: FatalError.
Action start 1:18:52: FatalError.
Info 2826. Control BottomLine on dialog FatalError extends beyond the boundaries of the dialog to the right by 4 pixels.
Action 1:18:52: FatalError. Dialog created
MSI (c) (4C:FC) [01:18:56:403]: Doing action: AI_SHOW_LOG
Action 1:18:56: AI_SHOW_LOG.
Action start 1:18:56: AI_SHOW_LOG.
MSI (c) (4C:50) [01:18:56:413]: Invoking remote custom action. DLL: C:\Users\ADMINI~1\AppData\Local\Temp\4\MSI4F0E.tmp, Entrypoint: LaunchLogFile
Action ended 1:18:56: AI_SHOW_LOG. Return value 1.
MSI (c) (4C:FC) [01:18:56:513]: Doing action: AI_CleanPrereq
Action 1:18:56: AI_CleanPrereq.
Action start 1:18:56: AI_CleanPrereq.
MSI (c) (4C:9C) [01:18:56:517]: Invoking remote custom action. DLL: C:\Users\ADMINI~1\AppData\Local\Temp\4\MSI4F7C.tmp, Entrypoint: CleanPrereq
Action ended 1:18:56: AI_CleanPrereq. Return value 1.
Action ended 1:18:56: FatalError. Return value 2.
Action ended 1:18:56: INSTALL. Return value 3.
MSI (c) (4C:A8) [01:18:56:598]: Destroying RemoteAPI object.
MSI (c) (4C:B8) [01:18:56:600]: Custom Action Manager thread ending.
Property(C): DB_CHOICE = mysql
I tried to install the second time (without uninsall) and I have choosed the Repair option than I got the following ODBC error message.
I include the log file's error part.
MSI (s) (58:E8) [01:38:38:236]: MainEngineThread is returning 1603
MSI (s) (58:68) [01:38:38:242]: RESTART MANAGER: Session closed.
MSI (s) (58:68) [01:38:38:244]: User policy value 'DisableRollback' is 0
MSI (s) (58:68) [01:38:38:244]: Machine policy value 'DisableRollback' is 0
MSI (s) (58:68) [01:38:38:244]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (58:68) [01:38:38:244]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows
\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (58:68) [01:38:38:245]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows
MSI (s) (58:68) [01:38:38:251]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be
denied. Counter after decrement: -1
MSI (s) (58:68) [01:38:38:252]: Restoring environment variables
MSI (s) (58:68) [01:38:38:256]: Destroying RemoteAPI object.
MSI (s) (58:0C) [01:38:38:256]: Custom Action Manager thread ending.
MSI (s) (58:68) [01:38:38:256]: No System Restore sequence number for this installation.
MSI (c) (1C:80) [01:38:38:263]: Back from server. Return value: 1603
MSI (c) (1C:80) [01:38:38:263]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be
MSI (c) (1C:80) [01:38:38:264]: PROPERTY CHANGE: Deleting SECONDSEQUENCE property. Its current value is
'1'.
Action ended 1:38:38: ExecuteAction. Return value 3.
MSI (c) (1C:80) [01:38:38:265]: Doing action: FatalError
Action 1:38:38: FatalError.
Action start 1:38:38: FatalError.
by 4 pixels.
Action 1:38:38: FatalError. Dialog created
MSI (c) (1C:94) [01:39:54:814]: Doing action: AI_SHOW_LOG
Action 1:39:54: AI_SHOW_LOG.
Action start 1:39:54: AI_SHOW_LOG.
MSI (c) (1C:E0) [01:39:54:824]: Invoking remote custom action. DLL: C:\Users\ADMINI~1\AppData\Local\Temp
\4\MSI82B3.tmp, Entrypoint: LaunchLogFile
Action ended 1:39:54: AI_SHOW_LOG. Return value 1.
MSI (c) (1C:94) [01:39:54:891]: Doing action: AI_CleanPrereq
Action 1:39:54: AI_CleanPrereq.
Action start 1:39:54: AI_CleanPrereq.
MSI (c) (1C:14) [01:39:54:912]: Invoking remote custom action. DLL: C:\Users\ADMINI~1\AppData\Local\Temp
\4\MSI8302.tmp, Entrypoint: CleanPrereq
Action ended 1:39:54: AI_CleanPrereq. Return value 1.
Will these information be enough for you?
Thanks for your support,
Koksal Basar
koksalbasar
Postby Maxim » Thu Feb 16, 2017 9:20 am
Hello koksalbasar!
We have detected this issue in Windows Installation version! We are working on this! We will release update with fix soon.
Thank you very much for your notification!
Postby koksalbasar » Thu Feb 23, 2017 1:18 pm
Thanks for your effort. May I ask how long it takes to release the new patch, and how will I be informed?
Ps. I'm sorry for late response. I've moved my home to another city. I had some internet problems.
koksalbasar
Postby Maxim » Fri Feb 24, 2017 8:17 am
Hello koksalbasar!
I cannot say exact date, but not to lose time i recommend you to install Enterprise Edition. Complete the form and get a test 30-day licence key.
