Windows Enterprise Installation - Can't connect to Rabbit
Postby cedric.reymond » Fri Feb 10, 2017 8:22 am
I tried to install the Enterprise version on a Windows 2012 server.
I have followed the instruction but I can not go over the RabbitMQ connection.
The default settings are there, but I have the message:
Connection Refused HOST:localhost,......
I tried install 2 times already...
Let me know how to progress.
Thanks,
Cedric
cedric.reymond
Re: Windows Enterprise Installation - Can't connect to Rabbi
Postby Maxim » Fri Feb 10, 2017 8:43 am
Try to delete RabbitMQ and install once again.
Postby cedric.reymond » Fri Feb 10, 2017 9:01 am
already tried that....
cedric.reymond
Postby Maxim » Fri Feb 10, 2017 11:12 am
We have detected and reproduce that issue! Thank you very much for your notification! We will update last release with fix of the issue soon.
Postby cedric.reymond » Fri Feb 10, 2017 11:28 am
ok. Let us know when the issue a new version is available.
Will it be possible to backup document and settings from a docker community version to the windows Enterprise version?
Thanks
Cedric
cedric.reymond
Postby Maxim » Fri Feb 10, 2017 11:39 am
Yes, but you need to replace data from Community Edition to newly installed Enterprise Edition (it's easy), create backup through Control Panel (there is no such function in Community Edition cause it's free) and restore your Backup on OnlyOffice Windows version.
Community Edition => Enterprise Edition => OnlyOffice Windows version
Maybe it looks formidably but it's quite simple ;)
