Link download.onlyoffice.com not found
Postby wiye82 » Tue Jan 31, 2017 11:24 am
Hi ,
im trying to install community server on ubuntu 14.04 without using docker ,following instruction here http://helpcenter.onlyoffice.com/server ... ation.aspx, but when do apt-get update i got this error message :
W: Failed to fetch http://download.onlyoffice.com/repo/deb ... 4/Packages 404 Not Found [IP: 54.192.159.197 80]
W: Failed to fetch http://download.onlyoffice.com/repo/deb ... 6/Packages 404 Not Found [IP: 54.192.159.197 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
it seems that the link is not found , could onlyoffice support update the link , i cannot go further because of it .
anybody helps.....
thx
wiye82
Re: Link download.onlyoffice.com not found
Postby Maxim » Tue Jan 31, 2017 12:04 pm
Unfortunately sometimes we have some troubles with repo.It works now!
Postby wiye82 » Wed Feb 01, 2017 4:59 am
Hi Maxim , thx for your fast response .
now i already can update the repo .
but when im trying to install sudo apt-get install onlyoffice-communityserver , i got this error message :
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
onlyoffice-communityserver : Depends: mono-complete (>= 4.2) but it is not going to be installed
Depends: mono-4.0-service but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
do you have any idea whats wrong with it ?
please advise
thx
wiye82
Postby Maxim » Wed Feb 01, 2017 7:05 am
There is no mono! Community Server uses mono (version 3.2 or later), nginx and mysql-server as database. You should install mono. Learn here (Installing dependencies).
Users browsing this forum: Baidu [Spider] and 1 guest
