One Click installation does not launch, cannot connect
Postby TTownsend » Wed Jan 04, 2017 7:35 pm
I am trying to do the One Click install and I receive this error:
Could not connect to the server.
Check connection setting and try again.
Here is my setup:
Ubuntu Server 16.04 in VMware Workstation
Domain name resolves to my external IP, which is forwarded to the VM on the LAN
The OnlyOffice server can reach my VM.
I do "tail -f /var/log/auth/log" and receive this error: Jan 4 14:29:10 portal sshd[2515]: fatal: mm_answer_moduli: bad parameters: 2048 2048 1024
I have configured my sshd_config file according to instructions, but cannot make this launch.
Can anyone help with this?
TTownsend
Re: One Click installation does not launch, cannot connect
Postby Maxim » Thu Jan 05, 2017 10:30 am
Hello TTownsend!
I would advice you to install OnlyOffice with provided script, it's much easier i believe and not so complicated!
Postby TTownsend » Mon Jan 09, 2017 2:08 am
Thanks Maxim - I've done that and now I'm wrestling with performance issues (very verrrrry slow server responses).
TTownsend
Postby Maxim » Mon Jan 09, 2017 7:16 am
TTownsend wrote:.....I'm wrestling with performance issues (very verrrrry slow server responses).
Here is my answer
Postby TTownsend » Mon Jan 09, 2017 3:58 pm
Great, thanks for the link - that's useful for my other challenge.
About connecting to the One Click process, I heard that there might be a low-level bug in OpenSSH - is that what this is?
TTownsend
Postby Maxim » Tue Jan 10, 2017 8:44 am
One Click installation requires full access (open required ports, no firewalland and so on). There is a great chance that something can go wrong.
Users browsing this forum: Bing [Bot] and 1 guest
