Installation with docker and not running
Postby wiye82 » Wed Dec 28, 2016 3:54 pm
Hi ,
I just installed communityserver integrated with document and mail server with docker on fresh installation ubuntu 14.04
following instruction on http://helpcenter.onlyoffice.com/server ... stallation
all the instruction i had followed and no error at all .
but when im trying to access the server with http://ubuntu14.04 ip address , the browser saying the site can't be reached ..
i have no idea whats wrong with it , how to check the log in docker ..
or maybe is there any way to access the server ?
please advise
wiye82
Re: Installation with docker and not running
Postby Maxim » Mon Jan 02, 2017 12:44 pm
You should:
1
apt-get update
2 To check the status of docker containers
docker ps
docker status
Pay attention to ports (80, 443 must be shown)
3 Try to stop mail server container and check efficiency without it
4 For the mail server correct work you need to specify its hostname 'yourdomain.com' - did you do that?
I suppose, first of all, you should try to reinstall using provided script and learn here how to install with additional script parameters.
