Size doesn't match
Size doesn't match
Postby bobanmak » Fri Dec 02, 2016 4:48 pm
Hi OnlyOffice Team,
i'm trying to install the DocumentServer on my Debian server. After installing the Dependencys and the GPG-key i'm getting this error:
E: Fehlschlag beim Holen von http://download.onlyoffice.com/repo/debian/pool/main/o/onlyoffice-documentserver/onlyoffice-documentserver_amd64.deb Größe stimmt nicht überein
or in english: the size of the packet dosn't match.
Could you give me a hint, how can i solve this?
Thanks in advanced.
bobanmak
Re: Size doesn't match
Postby Pavel.Lobashov » Mon Dec 05, 2016 9:35 am
Hi, could you specify OS on which this error happened, I tried `ubuntu:16.04` and everything fine for me.
Pavel.Lobashov
Postby bobanmak » Mon Dec 05, 2016 12:22 pm
Hi Pavel,
i am using Debian 8.0 Jessie.
I was having an older Installation of OnlyOffice on this server, so i assume that the old GPG-Key ist still being used. Maybe the old GPG-Key it is not being replaced by the new Key.
Best Regards
Boban
bobanmak
Postby Pavel.Lobashov » Mon Dec 05, 2016 2:14 pm
bobanmak wrote:i am using Debian 8.0 Jessie.
Yeah, I tryed this one - and no errors.
bobanmak wrote:I was having an older Installation of OnlyOffice on this server, so i assume that the old GPG-Key ist still being used. Maybe the old GPG-Key it is not being replaced by the new Key.
Seems that is a problem. You can delete old key by using `apt-key del` command. See this stackoverflow entry.
Pavel.Lobashov
