Desktop Editors on Arch Linux
Postby p4r53c » Tue Nov 15, 2016 10:55 am
HI!
I'm an ArchLinux user and i would like to see Desctop Editors in Arch's AUR repos, but I have on any instructions on how to build the project from the source code.
Yours GUI installer doesn't resolve dependencies. :cry:
We have two ways:
1. Create PKGBUILD script to build DE by yours instructions, if you provide them :)
2. Create PKGBUILD of binaries package, if you describe in detail the dependencies.
Analysis a .deb package doesn't give us enough information about dependencies.
Can some one of DEVs help us?
More information about what I want - here.
Thanks!
p4r53c
Re: Desktop Editors on Arch Linux
Postby Maxim » Wed Nov 16, 2016 7:38 am
Here is the link for portable version and i hope it will help you!
Postby p4r53c » Wed Nov 16, 2016 10:59 am
Maxim wrote:Hello!
Hi!
Maybe something I don't understand, but this link redirects to http://www.onlyoffice.com/ ...
p4r53c
Postby Maxim » Wed Nov 16, 2016 11:36 am
Once again here it is http://teamlab.info/download-desktop.aspx
In the end of list of OnlyOffice versions you'll find portable version - Current Version: 4.1.2-33/Release Date: 11/15/2016 File Size: 241 MB/Platforms: Linux distribution (64-bit)
Postby p4r53c » Wed Nov 16, 2016 11:50 am
p4r53c wrote:
Maxim wrote:Hello!
Hi!
I grab a portable edition (http://download.onlyoffice.com/install/ ... x64.tar.gz) and tested it.
It works! Probably the AUR maintainers will make a package from portable edition...
But I don't understand why OF developers don't make GUI-installer for portable edition. Current Installer installs OF without dependent libraries.
Just extract in /opt/onlyoffice and create a desktop entry and symlink... that's all. :)
P.S. Can we speak Russian? :)
p4r53c
Postby p4r53c » Wed Nov 16, 2016 12:03 pm
Maxim wrote:Hello!
Nope :)
Link http://teamlab.info/download-desktop.aspx redirects me to http://www.onlyoffice.com/ .
I go to "Download" (http://www.onlyoffice.com/download-desktop.aspx) and In the end of list of OnlyOffice versions i find only DEB\RPM packages and GUI installer (Current Version: 4.1.2-33
Release Date: 11/2/2016 File Size: 185 MB
Seriously, I am not joking. :)
p4r53c
Postby Maxim » Wed Nov 16, 2016 12:37 pm
p4r53c wrote:P.S. Can we speak Russian? :)
You are welcome!
You downloaded exactly what i meant!
Postby p4r53c » Wed Nov 16, 2016 2:11 pm
You are welcome!
Tnx!
We try to create a PKGBUILD from portable.
But you link is broken :)
Request:
GET /download-desktop.aspx HTTP/1.1
Host: teamlab.info
User-Agent: Mozilla/5.0 (X11; Linux x86_64; rv:50.0) Gecko/20100101 Firefox/50.0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-US,en;q=0.5
Accept-Encoding: gzip, deflate
Referer: http://dev.onlyoffice.org/viewtopic.php?f=35&t=9268
X-Compress: 1
Connection: keep-alive
Upgrade-Insecure-Requests: 1
Resp:
HTTP/1.1 302 Found
Server: Microsoft-IIS/8.0
X-Powered-By: ASP.NET
Date: Wed, 16 Nov 2016 12:46:27 GMT
Content-Length: 0
As you see: HTTP/1.1 302 Found Moved Temporarily :)
p4r53c
Postby Maxim » Thu Nov 17, 2016 7:11 am
p4r53c wrote:I grab a portable edition.......
Have you downloaded portable version?
Postby p4r53c » Thu Nov 17, 2016 8:08 am
Yes, but not through your link.
I had a direct link. Through teamlab I can't download it.
Portable version works fine.
p4r53c
