Install of Community Server behind Office Proxy
Postby czerr » Mon Nov 14, 2016 11:01 am
When i install at my home community server i have no problem.
At work i'm behing a proxy. i export http_proxy and https_proxy in bash.bashrc, wgetrc,apt.conf, etc ...
So when i install onlyoffice-communityserver, i have these message :
Paramétrage de onlyoffice-communityserver (8.9.2.14) ...
dpkg: erreur de traitement du paquet onlyoffice-communityserver (--configure) :
le sous-processus script post-installation installé a retourné une erreur de sortie d'état 1
Des erreurs ont été rencontrées pendant l'exécution :
Any idea ? No pb when my server is connect directly on internet ...
Thanks Christophe
czerr
Re: Install of Community Server behind Office Proxy
Postby czerr » Mon Nov 14, 2016 1:43 pm
OK, i found the problem
In onlyoffice-communityserver.postinst there is this command :
mozroots --import --sync --machine --quiet
And this command have a problem with my office proxy ...
Is there a way to pass a proxy to this command? Otherwise pass a proxy parameter to Mono ?
Thanks for your answer
czerr
Users browsing this forum: Google [Bot] and 2 guests
