installation fails on ubuntu 16.04
Postby luke » Sat Oct 22, 2016 10:27 am
Hi guys,
I am trying to install onlyoffice on a fresh installed ubuntu 16.04 LTS server, but the installation fails. I followed the installation guid XX step by step, but it seems like the script is not ok:
mono-complete (4.6.1.5-0xamarin1) wird eingerichtet ...
onlyoffice-communityserver (8.9.2.14) wird eingerichtet ...
adduser: Warning: The home directory `/var/www/onlyoffice' does not belong to the user you are currently creating.
mysql: [Warning] Using a password on the command line interface can be insecure.mysql: [Warning] Using a password on the command line interface can be insecure.
[b]ERROR 1067 (42000) at line 2049: Invalid default value for 'creationDate'[/b]
dpkg: Fehler beim Bearbeiten des Paketes onlyoffice-communityserver (--configure):
 Unterprozess installiertes post-installation-Skript gab den Fehlerwert 1 zurück
Trigger für libc-bin (2.23-0ubuntu3) werden verarbeitet ...
Trigger für systemd (229-4ubuntu11) werden verarbeitet ...
Trigger für ureadahead (0.100.0-19) werden verarbeitet ...
Trigger für dictionaries-common (1.26.3) werden verarbeitet ...
aspell-autobuildhash: processing: en [en-common].
aspell-autobuildhash: processing: en [en-variant_0].
aspell-autobuildhash: processing: en [en-variant_1].
aspell-autobuildhash: processing: en [en-variant_2].
aspell-autobuildhash: processing: en [en-w_accents-only].
aspell-autobuildhash: processing: en [en-wo_accents-only].
aspell-autobuildhash: processing: en [en_CA-variant_0].
aspell-autobuildhash: processing: en [en_CA-variant_1].
aspell-autobuildhash: processing: en [en_CA-w_accents-only].
aspell-autobuildhash: processing: en [en_CA-wo_accents-only].
aspell-autobuildhash: processing: en [en_GB-ise-w_accents-only].
aspell-autobuildhash: processing: en [en_GB-ise-wo_accents-only].
aspell-autobuildhash: processing: en [en_GB-ize-w_accents-only].
aspell-autobuildhash: processing: en [en_GB-ize-wo_accents-only].
aspell-autobuildhash: processing: en [en_GB-variant_0].
aspell-autobuildhash: processing: en [en_GB-variant_1].
aspell-autobuildhash: processing: en [en_US-w_accents-only].
aspell-autobuildhash: processing: en [en_US-wo_accents-only].
Trigger für ufw (0.35-0ubuntu2) werden verarbeitet ...
Fehler traten auf beim Bearbeiten von:
root@onlyoffice2:/home/djoko# sudo apt-get install onlyoffice-communityserver
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
onlyoffice-communityserver is already the newest version (8.9.2.14).
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 5 nicht aktualisiert.
1 nicht vollständig installiert oder entfernt.
Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
Möchten Sie fortfahren? [J/n] j
[b]ERROR 1146 (42S02) at line 224: Table 'onlyoffice.wiki_pages' doesn't exist[/b]
I need help, what can I do to fix?
luke
luke
Re: installation fails on ubuntu 16.04
Postby Maxim » Fri Oct 28, 2016 1:00 pm
Unfortunately there is nothing you can do to fix, but we work to solve that problem. We can advice you to use Docker (http://helpcenter.onlyoffice.com/server/docker/community/index.aspx) or to install ONLYOFFICE dep. on Ubuntu 14.04.
