error during community server installation
Postby Yoann » Fri Feb 05, 2016 12:08 pm
I'm trying to install, on a new serveur, OnlyOffice Community Server on debian jessie 8 release.
At apt-get update command I'm receiving this message:
Paramétrage de onlyoffice-communityserver (8.7.264-0) ...
dpkg: erreur de traitement du paquet onlyoffice-communityserver (--configure) :
le sous-processus script post-installation installé a retourné une erreur de sortie d'état 1
Traitement des actions différées (« triggers ») pour libc-bin (2.19-18+deb8u2) ...
Des erreurs ont été rencontrées pendant l'exécution :
Can you help me ?
Thanks,
Yoann
Yoann
Re: error during community server installation
Postby Dean » Fri Feb 05, 2016 12:23 pm
Please try:
sudo apt-get remove onlyoffice-communityserver
sudo apt-get autoremove
And try installing once again.
Postby Yoann » Fri Feb 05, 2016 1:12 pm
Same error :-/
is it normal that the version, we can get for debian, on https://onlyoffice.org/fr/sources is 8.6 and the version with apt is 8.7 ?
Thanks for your help,
Yoann
Yoann
Postby Yoann » Mon Feb 08, 2016 8:19 am
thanks for your reply.
But i still have the problem.
Thanks again for your help,
Yoann.
Yoann
Postby Dean » Tue Feb 09, 2016 8:14 am
Could you please specify the full OS parameters: The kernel version, the OS version?
Postby Yoann » Tue Feb 09, 2016 11:20 am
Debian Jessie
Linux onlyoffice 2.6.32-43-pve #1 SMP Tue Oct 27 09:55:55 CET 2015 x86_64 GNU/Linux
Yoann.
Yoann
Postby Yoann » Fri Feb 12, 2016 8:32 am
i think i found the problem.
It's from reddis. Despite the apt error, If i try to launch onlyoffice i get this error :
2016-02-11 15:04:49,839 FATAL [1] ASC - Error while init config
System.TypeInitializationException: An exception was thrown by the type initializer for ASC.Core.CoreContext ---> System.TypeInitializationException: An exception was thrown by the type initializer for ASC.Common.Caching.AscCache ---> StackExchange.Redis.RedisConnectionException: It was not possible to connect to the redis server(s); to create a disconnected multiplexer, disable AbortOnConnectFail. UnableToResolvePhysicalConnection on PING
at StackExchange.Redis.ConnectionMultiplexer.ConnectImpl (System.Func`1 multiplexerFactory, System.IO.TextWriter log) [0x00000] in <filename unknown>:0
at StackExchange.Redis.ConnectionMultiplexer.Connect (StackExchange.Redis.ConfigurationOptions configuration, System.IO.TextWriter log) [0x00000] in <filename unknown>:0
at StackExchange.Redis.Extensions.Core.StackExchangeRedisCacheClient..ctor (ISerializer serializer, IRedisCachingConfiguration configuration) [0x00000] in <filename unknown>:0
at ASC.Common.Caching.RedisCache..ctor () [0x00000] in <filename unknown>:0
at ASC.Common.Caching.AscCache..cctor () [0x00000] in <filename unknown>:0
at ASC.Core.Caching.CachedTenantService..ctor (ITenantService service) [0x00000] in <filename unknown>:0
at ASC.Core.CoreContext.ConfigureCoreContextByDefault () [0x00000] in <filename unknown>:0
at ASC.Core.CoreContext..cctor () [0x00000] in <filename unknown>:0
at ASC.FullTextIndex.Service.ModuleInfo..ctor (System.String name) [0x00000] in <filename unknown>:0
at ASC.FullTextIndex.Service.Config.TextIndexCfg.<Init>b__0 (ASC.FullTextIndex.Service.Config.TextIndexCfgModuleElement e) [0x00000] in <filename unknown>:0
at System.Linq.Enumerable+<CreateSelectIterator>c__Iterator10`2[ASC.FullTextIndex.Service.Config.TextIndexCfgModuleElement,ASC.FullTextIndex.Service.ModuleInfo].MoveNext () [0x00000] in <filename unknown>:0
at System.Collections.Generic.List`1[ASC.FullTextIndex.Service.ModuleInfo].AddEnumerable (IEnumerable`1 enumerable) [0x00000] in <filename unknown>:0
at System.Collections.Generic.List`1[ASC.FullTextIndex.Service.ModuleInfo]..ctor (IEnumerable`1 collection) [0x00000] in <filename unknown>:0
at System.Linq.Enumerable.ToList[ModuleInfo] (IEnumerable`1 source) [0x00000] in <filename unknown>:0
at ASC.FullTextIndex.Service.Config.TextIndexCfg.Init () [0x00000] in <filename unknown>:0
2016-02-11 15:08:24,816 ERROR [1] ASC.TeamLabSvc - Can not stop service FullTextIndexLauncher: System.Threading.ThreadStateException: Thread has not been started.
at (wrapper managed-to-native) System.Threading.Thread:Join_internal (System.Threading.InternalThread,int,intptr)
at System.Threading.Thread.Join (TimeSpan timeout) [0x00000] in <filename unknown>:0
at ASC.FullTextIndex.Service.TextIndexerService.Stop () [0x00000] in <filename unknown>:0
at ASC.FullTextIndex.Service.FullTextIndexLauncher.Stop () [0x00000] in <filename unknown>:0
at ASC.TeamLabSvc.Program.OnStop () [0x00000] in <filename unknown>:0
We have this problem because redis with OpenVz/ProxMox is not stable (at least with our OpenVz version).
I test with an external redis (installed on a physical server) and OnlyOffice works.
But i have a question : Can we use an external redis-server without problem ?
Yoann
Yoann
Postby Dean » Fri Feb 12, 2016 8:34 am
we never made any tests with external redis. I will contact our developers to check if it works fine.
