TIP: Install license.lid upon deployment
Postby vincococka » Thu Dec 03, 2015 7:46 am
Dear onlyoffice team,
please mention somewhere inside Docker installation guide that if user wants to be able to apply license.lic file (via wizard.ashx), he MUST install also ControlPanel ...
Without control panel this option is not visible in wizard and then coauthoring is not possible.
vincococka
Re: TIP: Install license.lid upon deployment
Postby Dean » Fri Dec 04, 2015 12:29 pm
OK< thank you very much, we shall add it to documentation.
