DocumentServer and MySQL Community Server
Postby Paul » Wed Jun 24, 2015 5:26 am
I've try to install Onlyoffice Community Server and Document Server on Debian Jessie through debian repositories. Installation of Community Server went well and it's working fine but I've a problem with Document Server.
I've installed all required components and dependencies but when I run:
apt-get install onlyoffice-documentserver
I get:
The following packages have unmet dependencies:
onlyoffice-documentserver : Depends: mysql-server-5.6 (>= 5.6.4)
E: Unable to correct problems, you have held broken packages.
MySQL specs:
#dpkg -l mysql-server
mysql-server 5.6.25-2debian8 amd64 MySQL Server meta package depending on latest version
#mysql
Welcome to the MySQL monitor. Commands end with ; or \g.
Your MySQL connection id is 28
Server version: 5.6.25 MySQL Community Server (GPL)
Copyright (c) 2000, 2015, Oracle and/or its affiliates. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql> \q
Can anyone help me with this issue? What am I doing wrong?
Thank you,
Paul
Re: DocumentServer and MySQL Community Server
Postby Dean » Wed Jun 24, 2015 11:09 am
Did you try to update mysql-server? This package was automatically installed with our Community-server.
Postby Paul » Wed Jun 24, 2015 11:57 am
I did try to run apt-get upgrade but there is no packages to upgrade
My APT Repository:
deb http://download.onlyoffice.com/repo/debian squeeze main
Ign. http://repo.mysql.com jessie/mysql-5.6 Translation-pl_PL
Ign. http://repo.mysql.com jessie/mysql-5.6 Translation-en
Ign. http://repo.mysql.com jessie/mysql-apt-config Translation-pl_PL
Ign. http://repo.mysql.com jessie/mysql-apt-config Translation-en
Paul
Postby Dean » Wed Jun 24, 2015 1:24 pm
Forwarded to testing team, we detected the issue. sorry for the inconvenience.
Postby ArLex » Tue Aug 11, 2015 9:39 am
Dean wrote:Forwarded to testing team, we detected the issue. sorry for the inconvenience.
I have the same problem. What's about new deb-package with right dependences ?
ArLex
Postby ArLex » Tue Aug 11, 2015 9:41 am
I have the same issue. What's about solving ?
ArLex
Postby Dean » Tue Aug 11, 2015 12:33 pm
The problem is not in the unmet dependencies only - it is better to install the deb-packages on two different servers - or use Docker containers.
Postby craucy » Mon Dec 07, 2015 4:57 pm
Hello everyone,
Any news about this issue? Is-it solved?
Regards,
Christopher Raucy.
craucy
Postby Dean » Tue Dec 08, 2015 6:46 am
Hello, Cristopher.
Yes, it is. The solution is to use 2 separate servers for installation with deb-packages or use Docker.
