Unable to add e-mail domain
Postby kabo » Fri May 22, 2015 6:41 pm
I want to use OnlyOffice as my e-mail server. Not just an e-mail client for gmail or some other server, I want <mail.my.domain> to point to the OnlyOffice MailServer.
So I managed to get the docker images running on my ubuntu 14.04 after a little work (upgrading the kernel, manually starting the services in the communityserver-container, etc).
I started the dockers with docker-compose up -d
communityserver:
  image: onlyoffice/communityserver
  links:
   - documentserver:document_server
   - mailserver:mail_server
  ports:
   - "80:80"
   - "443:443"
  volumes:
  - /opt/onlyoffice/Data:/var/www/onlyoffice/Data
  stdin_open: true
  tty: true
documentserver:
  image: onlyoffice/documentserver
  stdin_open: true
  tty: true
mailserver:
  image: onlyoffice/mailserver
  hostname: <my.domain>
  privileged: true
  ports:
   - "25:25"
   - "143:143"
   - "587:587"
  stdin_open: true
  tty: true
Then I registered on the initial setup with my gmail e-mail.
Then I checked out the mailserver configuration documentation.
First I added my gmail-account there, as the instructions indicated. Then I clicked on Settings > Mail Server and got "Internal server error. Try again later."
I logged on to the communityserver-container.
$ sudo docker exec -it <container-id> bash
# less /var/log/onlyoffice/web.api.log
2015-05-22 18:17:28,237 ERROR [Threadpool worker] ASC.Api - method error: https://<my.domain>/api/2.0/mailserver/serverinfo/get.json?__=515981 - Server error
System.IO.InvalidDataException: No mail servers registered.
  at ASC.Mail.Server.Dal.ServerDal.LinkServerWithTenant (ASC.Common.Data.DbManager db) [0x00000] in <filename unknown>:0
  at ASC.Mail.Server.Dal.ServerDal.GetTenantServer () [0x00000] in <filename unknown>:0
  at ASC.Api.MailServer.MailServerApi.get_MailServer () [0x00000] in <filename unknown>:0
  at ASC.Api.MailServer.MailServerApi.GetUnusedDnsRecords () [0x00000] in <filename unknown>:0
  at ASC.Api.MailServer.MailServerApi.GetMailServer () [0x00000] in <filename unknown>:0
  at ASC.Api.MailServer.MailServerApi.GetMailServerFullInfo () [0x00000] in <filename unknown>:0
  at System.Reflection.MonoMethod.Invoke (System.Object obj, BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x00000] in <filename unknown>:0
Of course there are no mail servers registered, that's what I'm trying to accomplish!
I verified that the mail-services (dovecot, postfix, etc) were running on the MailServer-container as they should, no problem there.
What am I missing?
kabo
Re: Unable to add e-mail domain
Postby ThinkPrivacy » Mon May 25, 2015 10:07 am
I am also getting a 500 error but mine is at the last stage of setting up a mailserver. Sadly my system is only logging nginx errors/access for some reason so I am unable to get any further information other than the 500 error.
ThinkPrivacy
Postby AnaMih » Mon May 25, 2015 3:36 pm
Please send the "web.api" log file from /var/log/onlyoffice folder inside onlyoffice community_server container via email - support@onlyoffice.com
User avatar
Postby kabo » Tue May 26, 2015 9:12 pm
You got email :)
kabo
Postby AnaMih » Wed May 27, 2015 10:42 am
To kabo:
We've received your log file, thank you. According to the log files ONLYOFFICE Community Server can't "see" the mail server:
Please, make sure that you follow the instructions
Pay attention that the sequence of programs installation should be the following:
1) Installing ONLYOFFICE Document Server.
2) Installing ONLYOFFICE Mail Server.
3) Installing ONLYOFFICE Community Server (with linking mail and document servers).
User avatar
Postby ThinkPrivacy » Wed May 27, 2015 10:45 am
I did follow those instructions and I sent the command I launched them with via email.
ThinkPrivacy
Postby kabo » Wed May 27, 2015 1:34 pm
I'm using docker-compose up -d to start the containers. Does that not ensure the proper order?
kabo
Postby kabo » Thu May 28, 2015 9:00 pm
Tried starting them manually now, no difference. What port does the community server want to contact on the mail server? 25, 143 and 587 seem to be reachable.
// I ran this on the community server
root@e54aa5aef8a6:/# telnet mail_server 25
Trying 172.17.0.8...
Connected to mail_server.
Escape character is '^]'.
telnet> Connection closed.
root@e54aa5aef8a6:/# telnet mail_server 143
* OK [CAPABILITY IMAP4rev1 LITERAL+ SASL-IR LOGIN-REFERRALS ID ENABLE IDLE STARTTLS LOGINDISABLED] Dovecot ready.
root@e54aa5aef8a6:/# telnet mail_server 587
220 my.domain ESMTP Postfix
kabo
Postby kabo » Thu May 28, 2015 9:05 pm
I just thought of something, I think I'm using a self-signed certificate, could that be an issue?
kabo
Postby kabo » Thu May 28, 2015 9:27 pm
I also found this in /var/log/onlyoffice/mail.agg.errors.log on the community server
2015-05-28 21:02:37,882 Threadpool worker ERROR Task_13             : ProcessMessages() Tenant=0 User='00000000-0000-0000-0000-000000000ace' Account='my.account@gmail.com', MailboxId=1, UID=35168 Exception:
System.IO.FileNotFoundException: file not found
File name: '/var/www/onlyoffice/Data/addons/mail/Data/aggregator/0/00000000-0000-0000-0000-000000000ace/61db23faf6b943d9a40377d5a4c71240/body.html'
  at ASC.Data.Storage.DiscStorage.DiscDataStore.Delete (System.String domain, System.String path) [0x00000] in <filename unknown>:0
  at ASC.Mail.Aggregator.MailBoxManager.StoreMailBody (Int32 tenant, System.String user, ASC.Mail.Aggregator.Common.MailMessageItem messageItem) [0x00000] in <filename unknown>:0
  at ASC.Mail.Aggregator.MailBoxManager.MailReceive (ASC.Mail.Aggregator.Common.MailBox mailbox, ActiveUp.Net.Mail.Message message, Int32 folderId, System.String uidl, System.String md5, Boolean hasParseError, Boolean unread, System.Int32[] tagsIds, ASC.Mail.Aggregator.Common.MailMessageItem& messageItem) [0x00000] in <filename unknown>:0
/var/www/onlyoffice/Data is shared from the host (/opt/onlyoffice/Data). Could this be related to file permissions? What permissions should /opt/onlyoffice/Data have on the host?
kabo
Next
Users browsing this forum: Google [Bot] and 2 guests
