Forum rules
0
23161
21 December 2020
Updating containers?
3
80
17 April 2024
2
36
17 April 2024
To-big-to-fit tables sould be more easy to modify
4
108
17 April 2024
0
10
17 April 2024
Run docs server without nextcloud
3
54
17 April 2024
Simplified Chinese translation optimization suggestions
4
87
17 April 2024
2
55
17 April 2024
28
2149
17 April 2024
Conflict between forced save and automatic save
2
68
17 April 2024
Sleep/wake-up - OO closes without any information & file are not save
21
760
17 April 2024
Running OnlyOffice with Docker-Compose - WOPI - Connection refused while connecting to upstream
37
6209
16 April 2024
0
36
16 April 2024
Bullet list are acting weird when changing font size
0
56
15 April 2024
1
51
16 April 2024
Endnotes disappear after conversion from Footnotes
10
136
16 April 2024
Why, when copy-pasting a shape a new line is inserted?
1
49
16 April 2024
6
144
16 April 2024
Font selector - should filter the whole font name, not just the begining of the font name
1
39
16 April 2024
Docker document server and nextcloud : document could not be saved
3
91
16 April 2024
How to modify the default font of docs
3
170
16 April 2024
OO Docs-enterprise: Connectivity Issues with OnlyOffice and Nextcloud via HTTPS and Custom Domain
2
101
16 April 2024
Is it possible to access Shared Drives in our Google Workspace?
6
157
16 April 2024
0
32
16 April 2024
How to getTable in Presentation?
2
79
16 April 2024
App does not open files
0
41
15 April 2024
In the Community version I can't add an external link to a folder, there is an option to grant external user access for files only. Really need external link access for folders - it doesn't work! Also adding multiple external links doesn't work
4
351
15 April 2024
相同字体显示效果不同?
2
86
15 April 2024
Network subsystem is down
6
123
15 April 2024
How to debug macros!
24
2006
15 April 2024
