Dependency on mono
Dependency on mono
Postby thalperi » Tue Jul 24, 2018 9:56 am
tamir@minimi:~$ sudo apt-get install onlyoffice-communityserver
[sudo] password for tamir:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
onlyoffice-communityserver : Depends: mono-webserver-hyperfastcgi but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
and then
tamir@minimi:~$ sudo apt-get install mono-webserver-hyperfastcgi
mono-webserver-hyperfastcgi : Depends: libevent-2.0-5 (>= 2.0.10-stable) but it is not installable
Depends: libevent-pthreads-2.0-5 (>= 2.0.10-stable) but it is not installable
Could somebody please help me resolve these dependency issues?
thalperi
Re: Dependency on mono
Postby Maxim » Thu Jul 26, 2018 7:38 am
Hello thalperi!
What is your server OS?
Postby bevy » Fri Aug 17, 2018 12:43 am
I am running into this same issue on Ubuntu 18.04.
Steps to reproduce:
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
echo "deb https://download.mono-project.com/repo/ubuntu stable-bionic main" | sudo tee /etc/apt/sources.list.d/mono-official-stable.list
sudo apt update
sudo apt install mono-complete
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys CB2DE8E5
sudo echo "deb http://download.onlyoffice.com/repo/debian squeeze main" | sudo tee /etc/apt/sources.list.d/onlyoffice.list
sudo apt update
sudo apt install onlyoffice-communityserver
Result:
bevy
