Document couldnt be saved onlyoffice
Postby chrisda55 » Sat Jun 23, 2018 4:27 pm
hello,
I followed this tutorial to install only office : https://www.linuxbabe.com/docker/onlyof ... ion-docker
Everything went well until when im trying to open a document i get an error that says : "the document couldnt be saved, please check connection settings etc" and i cant even click OK it actually ignore my clicks.
Thanks for your help! :)
chrisda55
Re: Document couldnt be saved onlyoffice
Postby Maxim » Mon Jun 25, 2018 6:19 am
Hello chrisda55!
You should check accessibility with command wget from both servers to each other (from Nextcloud to the Document Server and from the Document Server to Nextcloud).
wget http(s)://your_IP_or_domain
