Integrate onlyoffice with PHP example.
Postby napoleon211092 » Thu May 17, 2018 8:27 am
I try to use onlyoffice with PHP example API.
I follow this guide https://api.onlyoffice.com/editors/example/php to install.
I succeed install document server in address: http://192.168.131.132, here is image of document server.
document server is runing.
Then I download PHP code in same server with document server (different port: port 81).
Then, I change config.php like this:
$GLOBALS['DOC_SERV_CONVERTER_URL'] = "http://192.168.131.132:80/ConvertService.ashx";
$GLOBALS['DOC_SERV_API_URL'] = "http://192.168.131.132:80/web-apps/apps/api/documents/api.js";
$GLOBALS['DOC_SERV_PRELOADER_URL'] = "http://192.168.131.132:80/documentserver/web-apps/apps/api/documents/cache-scripts.html";
It show me the GUI like this.
I can upload my doccument to server. But I cant view or edit my office file. This is error like this:
Please help me.
Thank you.
napoleon211092
Re: Integrate onlyoffice with PHP example.
Postby Maxim » Mon May 21, 2018 11:05 am
Hello napoleon211092!
i hope it will help you to find the solution.
Postby napoleon211092 » Wed May 23, 2018 3:52 am
Thanks Maxim. :D
napoleon211092
