Docker install + Nginx + Nextcloud
Postby 3th3r » Mon Jan 22, 2018 9:57 pm
HI,
I've try several hours to install onlyoffice for nextclout. With the officiel docker image.
Cant get it to work I've always an error, i fix something, somthing else break.
My nginx conf, in this cas is not relevant, nextcloud and onlyoffice, can communicate directly trough their dns name (under the docker bridge).
If I dont use ssl / hhtps, in nextcloud the server is availaible but return "error while downloading". And when is use https / ssl, i can't event contact the server with or without nginx, and nextcloud return "bad request or timeout".
So, wath's the solution ? Using "Office" ?
3th3r
Re: Docker install + Nginx + Nextcloud
Postby Maxim » Tue Jan 23, 2018 8:14 am
Hello 3th3r!
More details please. How did you install?
