local doc link to email domain issue
Postby cksoft » Mon Jan 01, 2018 4:21 pm
Hi all,
When i'm trying to sent an email with attachement (just the link of local doc) my domain is not the good for the link, so :
i have : http://onlyoffice/products/files/doceditor.aspx?
instead of
https://my.domaine.com/products/etc.....
there is a solution to change that ?
i'm using onlyoffice / Linux (not docker) Version 9.5.3.549 with debian 4.9.0-4-amd64 #1 SMP Debian 4.9.65-3+deb9u1
cksoft
[SOLVED] Re: local doc link to email domain issue
Postby cksoft » Mon Jan 01, 2018 10:53 pm
finaly i reply to myself thanks to user and post in this forum :)
see here
viewtopic.php?f=37&t=6351
My solution :
replace in this file (nginx conf) /etc/nginx/includes -> onlyoffice-communityserver-common.conf
set $X_REWRITER_URL $scheme://$http_host;
by your domain :
set $X_REWRITER_URL https://your.domain.com;
save and reload nginx (nginx -s reload)
and it's done.
Bye and happy new year to all
cksoft
Postby Maxim » Tue Jan 02, 2018 7:36 am
Hello cksoft!
It's great that you have found a solution!
Happy new year!
