Default Container Volumes
Postby isabeljason » Wed Sep 20, 2017 11:40 am
I am a complete new to docker and I understand the way default container volumes are made. Container volumes are inside of /var/lib/docker/volumes. can I change the default volume directory for each container, to a directory/partition of choice on the host system?
isabeljason
Re: Default Container Volumes
Postby Maxim » Thu Sep 21, 2017 5:51 am
Hello isabeljason!
Have no idea, you should visit docker forums. This forum is dedicated to Onlyoffice.
