Error while trying to connect: Bad request or timeout error
Postby bertalanimre » Tue Sep 12, 2017 10:07 am
Hello Forum,
I'm trying to implement onlyoffice into my nextcloud installation. However I'm quite stuck with it. Here is the environment I'm using:
    - CentOS 7
    - MySQL
    - NextCloud
I'm trying to install owncloud according to the install guide provided by the developers here: https://api.onlyoffice.com/editors/owncloud The only difference I've done is that I've installed the integration app from the nextcloud app store. I get stuck at "Configuring ownCloud/Nextcloud ONLYOFFICE integration app".
Whenever I enter the URL for my nextcloud server I get an error saying
Anyone encountered this before? How may continue? I'm a bit lost, just rolled back my server with a whole day cause I've messed it up by installing all sort of things trying to make this work. Isn't the documentserver supposed to be the same as the nextcloud server?
Thanks in advance!
Bert
bertalanimre
Re: Error while trying to connect: Bad request or timeout er
Postby Maxim » Fri Sep 15, 2017 2:24 pm
Hello bertalanimre!
1 Did you install Document Server? How?
2 Do you use separate servers for Doc Server and NextCloud or one?
3 "Bad request or timeout error" means that there is no connection between servers.
4
