French encoding
French encoding
Postby NeoPhil » Wed Sep 06, 2017 1:07 pm
After a clean install on Ubuntu 16.04 (repository method, not docker), with HTTPS and Document Server working, i can't setup the french translation correctly.
Seems the encoding is wrong, for exemple :
Aucune tâche n'a été encore créée
Les tâches vous permettent de distribuer le travail aux participants du projet de manière égale, de définir les responsables pour les différentes parties du projet. Ajoutez des tâches, déterminez ceux qui sont responsables, gérez le travail d'équipe.
I tried to change database charset to UTF-8, but no luck...
Any ideas ?
Thanks !
NeoPhil
Re: French encoding
Postby Maxim » Wed Sep 06, 2017 1:45 pm
Hello NeoPhil!
Please specify what instruction you followed to install Onlyoffice and
translation?
Onlyoffice doesn't translate.
Re: French encoding
Postby NeoPhil » Wed Sep 06, 2017 2:03 pm
Thanks for answer Maxim,
I follow this instruction to install OO :
It's a fresh Ubuntu server 16.04 (LXC Container on Proxmox Host). No error during install, OO working like a charm.
Sorry, as "translation", I meen simply change language to "French (France)" in interface settings.
NeoPhil
Re: French encoding
Postby Maxim » Mon Sep 11, 2017 7:14 am
Nello NeoPhil!
It needs to change database charset to UTF-8.
What mysql version did you install?
Ia there one database only?
Re: French encoding
Postby NeoPhil » Thu Sep 14, 2017 4:58 pm
Maxim wrote:Nello NeoPhil!
Hello Maxim,
I think database is already to UTF-8.
| Variable_name          | Value |
| character_set_database | utf8  |
1 row in set (0,00 sec)
and MySQL Version is 5.7.19
... I don't understand, some chararcters are good and not others... :
French Charset
NeoPhil
Re: French encoding
Postby Maxim » Fri Sep 15, 2017 12:27 pm
Hello NeoPhil!
We are trying to find the problem, please wait. I will try to reply as soon as possible.
Re: French encoding
Postby NeoPhil » Mon Sep 18, 2017 8:49 am
Maxim wrote:Hello NeoPhil!
Thank you very much.
NeoPhil
Re: French encoding
Postby NeoPhil » Mon Sep 18, 2017 3:07 pm
For information, I just try another fresh install folowing this guide : https://helpcenter.onlyoffice.com/serve ... ation.aspx
>> Same results when switching language to French...
NeoPhil
Re: French encoding
Postby Maxim » Tue Sep 19, 2017 6:26 am
Hello NeoPhil!
Thank you for the information!
Try to install docker version
Re: French encoding
Postby Blackjack » Sun Jan 21, 2018 8:12 pm
Hi Maxim,
i have the same cofiguration with https, Ubuntu 16.04 (LXC Container Proxmox) and the same problem with German special characters :shock:
I already checked the mysql database and it is also in UTF-8.
Thanks for your help
Blackjack
Next
