Ubuntu - Document Server - 502 Bad Gateway
Postby robotme » Sun Aug 27, 2017 3:52 am
I have installed NextCloud on an Ubuntu PC.
I am trying to set up OnlyOffice to work with NextCloud.
I did not want to (and don't want to) use Docker to Install the Document Server.
So I followed this guide :
I set the port to 8080 but after installation when i type in http://localhost:8080 I get http://localhost:8080/welcome/ 502 Bad Gateway nginx.
See image http://imgur.com/a/8AZ6q
Could some one please help me resolve this issue, I don't know what to do. Any help, suggestions, or links to help resolve this issue will be greatly appreciated.
robotme
Re: Ubuntu - Document Server - 502 Bad Gateway
Postby Maxim » Wed Aug 30, 2017 7:45 am
Hello robotme!
Have you installed all dependencies correctly?
PostgreSQL: version 9.1 or later
NGINX: version 1.3.13 or later
Node.js: version 6.9.1 or later
libstdc++6: version 4.8.4 or later
Redis
RabbitMQ
Did Any issues while installation process appear?
What is OS on your server? Fresh Ubuntu?
