Enterprise Windows with SSL/HTTPS
Postby bdearlove » Wed May 31, 2017 3:13 pm
Good Day,
I attempted to upgrade OnlyOffice Enterprise Windows to the latest version which was successful. Unfortunately it reset me to HTTP. I tried following the guide below to reconfigure to HTTPS but it only gives me access to Document Server via HTTPS. Im looking to configure all OnlyOffice to HTTPS. How do I do with in OnlyOffice Enterprise Windows? Thanks.
Guide I used: https://helpcenter.onlyoffice.com/serve ... https.aspx
bdearlove
Re: Enterprise Windows with SSL/HTTPS
Postby Maxim » Thu Jun 01, 2017 8:04 am
Hello bdearlove!
Use this instruction.
