[solved] Can't access SMTP parameters
Postby bevito » Fri Apr 28, 2017 2:40 pm
We're using OnlyOffice Enterprise with Docker (CP : 1.6.1.106, CS : 8.9.2.27, DS : 4.3.3.4)
Recently I discovered that email notifications did not work anymore.
So, I tried to access SMTP parameter.
The page is loading forever (you can see the attachment).
I tried to reinstall OnlyOffice (removed images), but the problem still occured.
What can I do to solve this issue ?
Best regards.
bevito
Re: Can't access SMTP parameters
Postby Maxim » Tue May 02, 2017 12:37 pm
Hello bevito!
Please specify the old image did you delete before new installation?
Postby bevito » Tue May 02, 2017 2:59 pm
Hi Maxim,
I used this commands :
docker rm container_id
and
docker rmi image_name
and I used the bash script to reinstall OnlyOffice
bash enterprise-install.sh -ims false
Thanks for your help.
bevito
Postby Maxim » Wed May 03, 2017 7:16 am
Hello bevito!
Please send us (private message) logs of Community Server - /app/onlyoffice/CommunityServer/logs
Postby bevito » Wed May 03, 2017 9:30 am
Hi Maxim,
The Community Server "logs" folder is about 1.3 Go.
Would you like all the content of this folder ?
Is there any way to configure logs rotations ?
Thanks for your answer.
bevito
Postby Maxim » Thu May 04, 2017 7:25 am
Hello bevito!
We suppose that smth. happend to your database while updating or anything else.
So you should execute on host machine and then restart docker container
docker exec -it onlyoffice-community-server mysql -e "UPDATE onlyoffice.core_settings SET tenant=\"-1000\" WHERE id=\"SmtpSettings\";"
I hope it will help you.
Postby bevito » Thu May 04, 2017 5:16 pm
Hi Maxim,
The above command gave this result :
ERROR 1062 (23000) at line 1: Duplicate entry '-1000-SmtpSettings' for key 'PRIMARY'
Is there anything I can do to help you ?
Thanks a lot for your help and your time.
bevito
Postby Maxim » Fri May 05, 2017 8:20 am
Hello bevito!
Try this
docker exec -it onlyoffice-community-server mysql -e "delete from onlyoffice.core_settings WHERE id=\"SmtpSettings\";"
restart container and check SMTP parameters
Postby bevito » Fri May 05, 2017 10:06 am
Hi Maxim,
I just tested your command, then restart the "onlyoffice-community-server".
On our portal settings, the page is still loading forever.
What can I do to help you ?
bevito
Postby bevito » Sat May 06, 2017 7:14 am
Hi Maxim,
I reinstalled OnlyOffice this morning to update all versions ( Community Server 8.9.2.2.7 -> 9.0.0.300, Control Pannel 1.6.1.106 -> 2.0.0.82)
After updating, the SMTP settings page works.
bevito
Next
