two factor authentication
Postby cartenca » Tue Apr 18, 2017 9:46 am
I need to enable "two factor authentication"
how can I do?
Is there a guide?
Thanks
Carlo
cartenca
Re: two factor authentication
Postby Maxim » Tue Apr 18, 2017 11:22 am
Hello cartenca!
See here
Postby cartenca » Wed Apr 19, 2017 6:03 am
Hi Maxim,
Thank you, but I'd need to know if I can do it with my enterprise version...
Is there any add-on or particular configuration?
best regards
Carlo
cartenca
Postby Maxim » Thu Apr 27, 2017 5:55 am
Hello Carlo!
It works on SAAS version only!
