High memory usage
High memory usage
Postby Georgas » Mon Apr 17, 2017 12:37 pm
For enterprise edition docker version in system requirements says it's minimum 6gb of ram https://helpcenter.onlyoffice.com/serve ... ments.aspx we have on server 16gb of ram and load is about 60-70% after restart, few hours later ram and swap usage are 100% it's mean 16 gb of ram and 8gb of swap . First I did install onlyoffice with mail server but after I try connect via imap and didn't work because of wrong password I uninstall mail server and setup own mail server . And I did import 2 big mailboxes 1 is about 60Gb of data another 90Gb of data , I setup it week ago can it's be that it's still importing mails so long ? Mail server is on the same server just not on the docker . I seen at email setup there was option import only 30 days emails is it mean that I won't be able to see/search through older emails or it's just mean that older emails won't be imported and can search or read them when I need through onlyoffice ?
Screenshot at Apr 16 22-33-02.jpg (146 KiB) Viewed 1968 times
Georgas
Re: High memory usage
Postby Maxim » Mon Apr 17, 2017 1:19 pm
Hello Georgas!
...I uninstall mail server and setup own mail server..
Do you mean OnlyOffice Mail Server?
Yes, by default there is such limitation for emails downloading. They won't be imported but you can search them and read them. Also if a user disable this function "Import messages only for the last 30 days" than all emails would be imported.
30 days.png (102.63 KiB) Viewed 1966 times
Postby Georgas » Tue Apr 18, 2017 6:27 am
Hello Maxim,
So I deleted imap accounts and start from scratch adding only 1 account and import only emails for the last 30 days . After those emails was imported I notice that I can search and read only emails within last 30 days I can't read or search older emails . Can you tell me how long should it take to import about 60k emails ? And is it normal you seen screenshot that ram and swap 100% used ? I can't even ssh to the server without rebooting server .
Another question I have why you not allowing corporate customers to use imap connection to onlyoffice email server ? Because of that limitation I had to built mail server move all emails there and from there move all emails to onlyoffice . If we will be able to use onlyoffice imap access so it's will be enough with imapsync to sync emails to onlyoffice and thats it . But from this thread viewtopic.php?f=7&t=9473&p=13206&hilit=thunderbird#p13206 I understand it's built specially like this so people can't connect via mobile device to their email account by using onlyoffice mail server . And you ask me about deleted mail server so yes I deleted from docker onlyoffice mail server container .
For now we don't have no one user working on the program and it's using so much ram so i was wondering how much ram will need when we have 10-15 users . And if before trial ends I will be able to import all emails I have one more email account with around 90k emails which I need to have in onlyoffice as well .
Thank you
Georgas
Postby Maxim » Tue Apr 18, 2017 7:43 am
Hello Georgas!
I cannot see your screenshot, i see this
Please attach your screenshot one more time.
    I have no idea honostly to say, it depends on many things.
    I suppose it's not.
Send us logs please mail.agg.log You can send to support@onlyoffice.com or send me private message
for Docker - /app/onlyoffice/CommunityServer/logs
for Linux - /var/log/onlyoffice/
Also i think you should examine all processes and identify which process is using so much memory.
Postby Georgas » Tue Apr 18, 2017 11:30 am
Didn't knew that you image is broken . You can see image here http://imgh.us/Screenshot_at_Apr_18_13-40-53.jpg so this screenshot I just took . It's syncs only 1 mailbox and I having again hard time open pages on the server . So yesterday I start sync it and load was about 60% as you see this morning it's already 100% ram and swap . But even when server not syncing emails load are about 60% of ram . Here I have screenshot right after server was restarted http://imgh.us/Screenshot_at_Apr_16_19-44-36.jpg . Not sure I already thinking maybe to reinstall it . Can I just delete container and reinstall it ?
Georgas
Postby Maxim » Tue Apr 18, 2017 2:14 pm
Georgas try next solution
1. Copy file onlyofficeMailAggregator to host machine /root
2. Run commands:
docker cp /root/onlyofficeMailAggregator onlyoffice-community-server:/etc/init.d/onlyofficeMailAggregator
docker exec -it onlyoffice-community-server /etc/init.d/onlyofficeMailAggregator restart
3. Restart container
InitAggregatorScript.tar
(5.5 KiB) Downloaded 46 times
Postby Georgas » Thu Apr 20, 2017 6:35 am
Hello Maxim,
Thanks for the patch, I think now all good .
Georgas
Postby Maxim » Thu Apr 20, 2017 7:24 am
Hello Georgas!
You are welcome! :D
