Problem with run-document-server.sh
Postby dsi-lille » Wed Apr 12, 2017 10:04 am
a little game for you :)
what's wrong with those lines (from run-document-server.sh script) :
  if [ ${RABBITMQ_SERVER_HOST} != "localhost" ]; then
    update_rabbitmq_setting
  else
    LOCAL_SERVICES+=("redis-server")
  fi
  if [ ${REDIS_SERVER_HOST} != "localhost" ]; then
    update_redis_settings
  else
    LOCAL_SERVICES+=("rabbitmq-server")
  fi
could you please be careful and test your script before any release ?
Thanks a lot,
Yoann
dsi-lille
Re: Problem with run-document-server.sh
Postby Maxim » Wed Apr 12, 2017 11:35 am
Hello Yoann!
Thank you for your error notification!
Also it would be great if you post such errors on GitHub
Fix
Thank you again!
