Resize Calendar Cell
Postby kiar » Wed Mar 08, 2017 5:01 pm
Unfornately we have a lot of events in our calendar, and we gain time when we are able to see all events at first glance.
Is it possible to resize the calendar cell ?
I didn't find a way to do it on Onlyoffice.
If not, where can I change this ?
I found the function setMinHeight in WebStudio2/addons/calendar/UserControls/fullcalendar/fullcalendar.js which seems to fix the min-height of the div inner the cell, but I didn't find a way to modify the behaviour.
It would be great to solve this :)
Thanks
kiar
Re: Resize Calendar Cell
Postby Maxim » Thu Mar 09, 2017 8:12 am
Hello kiar!
We will keep your wish in our minds, there is no possibility to do that now.
