Control Panel Logon Loop Windows
Postby bdearlove » Wed Mar 01, 2017 3:02 am
Good Day,
I am running Enterprise edition Windows version 8.9.2. When trying to get to control panel it asks and re-asks for my username/password but does not let me though. Anything I can do to troubleshoot the issue would be appreciated, thanks.
bdearlove
Re: Control Panel Logon Loop Windows
Postby Maxim » Wed Mar 01, 2017 8:23 am
Hello bdearlove!
Please specify what build did you install? The last one is 92.
Postby bdearlove » Thu Mar 02, 2017 1:59 pm
Yes, Windows Version: Version 8.9.2
Thanks.
bdearlove
Postby Maxim » Thu Mar 02, 2017 2:55 pm
Hello bdearlove!
It's very hard to determine the problem. Please download new realease and try to reinstall OO.
Postby bdearlove » Thu Mar 23, 2017 1:49 pm
Thanks. I have tried using that installed to upgrade, I have kept services running and also tried stopping them all and keep getting the same error. (Screenshot attached)
bdearlove
Postby Maxim » Fri Mar 24, 2017 6:56 am
Hello bdearlove!
We have detected that bug earlier. We will fix it, but you can try next:
1 uninstall RabbitMQ x64, Erlang x64 and Redis x64
2 delete all temporary files and registry keys
3 restart and reinstall OO
4 If it does not work try (if you have such option) on fresh Windows installation
