[solved] Problems with latest updates
Re: Problems with latest updates
Postby bevito » Thu Mar 02, 2017 9:51 pm
Hi Maxim,
I stopped and started all the conainers without any luck.
I did some tests :
With linux client (Debian jessie 64)
- Google Chrome (56.0.2924.87 (64-bits)) : scrolling with wheel's mouse on spreadsheets works
- Mozilla Firefox (51.0.1 (64 bits)) : scrolling with wheel's mouse on spreadsheets doesn't work
With windows client (Windows 7 Pro 64)
- Internet Explorer (11.0.9600.17843) : scrolling with wheel's mouse on spreadsheets works
I can confirm that scrolling with wheel's mouse works with Mozilla Firefox on Documents and Presentation.
I hope it can help you.
Thanks for your help.
bevito
Postby Maxim » Fri Mar 03, 2017 6:28 am
Hello bevito!
Thank you for tests and your info. We will fix it in 4.3 release.
Previous
