[Document Server] External RabbitMQ
Postby dsi-lille » Thu Feb 02, 2017 3:41 pm
i want to use an external RabbitMQ server on my document server.
Following the documentation, i set those environnements variables on document server startup :
RABBITMQ_SERVER_HOST: The IP address or the name of the host where the RabbitMQ server is running.
RABBITMQ_SERVER_USER: The RabbitMQ server user name.
RABBITMQ_SERVER_PASS: The password set for the RabbitMQ account.
But it's not working and i have this error :
[2017-02-02 15:02:31.914] [ERROR] nodeJS - [AMQPE] Error: Handshake terminated by server: 403 (ACCESS-REFUSED) with message "ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile."
    at afterStartOk (/var/www/onlyoffice/documentserver/server/Common/node_modules/amqplib/lib/connection.js:218:12)
After some investigagtion : even if RABBITMQ_SERVER_USER and RABBITMQ_SERVER_PASS are set, Document server are not using it.
Document server use the default credential from RabbitMQ : guest
I take look a the code and this is what i found :
The nodejs library used for connecting to a RabbitMQ is amqplib (http://www.squaremobius.net/amqp.node/channel_api.html)
In rabbitMQCore.js file, all the parameters (login, password, timeout...) used to establish a connection are stored in an array (connetOptions).
But referring to the documentation of the library (http://www.squaremobius.net/amqp.node/c ... ml#connect), the login / password have to be stored in the URI.
Something like that :
amqp://guest:guest@localhost:5672
If there is no login/password in the URI, the nodejs library use guest/guest as login and password.
Am i correct ?
Can you fix this ?
Thanks a lot,
Yoann
dsi-lille
Re: [Document Server] External RabbitMQ
Postby Maxim » Fri Feb 03, 2017 12:39 pm
Hello Yoann!
Thank you for your error notification! We will fix it next release (4.3) for sure!
Try to use login and password like username:password@host for RABBITMQ_SERVER_HOST
general format for RABBITMQ_SERVER_HOST will be [username:password@]host[:port][vhost]
Postby dsi-lille » Mon Feb 27, 2017 1:12 pm
Hello Maxim,
just had a little time to test it.
But this doesn't work, the document-server container doesn't start completely.
It's stuck with this error message :
nc: getaddrinfo: Name or service not known
Waiting for connection to the user:passwd@host host on port 5672
The problem came from run-document-server.sh script.
the function below can't work with a hostname format like this [username:password@]host[:port][vhost] :
waiting_for_connection(){
  until nc -z -w 3 "$1" "$2"; do
    >&2 echo "Waiting for connection to the $1 host on port $2"
    sleep 1
  done
Thanks for your help,
Yoann
dsi-lille
Postby Maxim » Mon Mar 13, 2017 8:33 am
Thank you for your info!
