Can't acces to control-panel
Postby dsi-lille » Wed Dec 07, 2016 12:26 pm
since the last update (Community Server : 8.9.2.19, Document Server : 4.2.0.305, Control Panel : 1.6.1.91), when i click on the control panel link from the parameters page i'm redirect to the login page (https://escola.ac-lille.fr/auth.aspx).
If i authenticate i get back to the home page.
Thanks for your help,
Yoann
dsi-lille
Re: Can't acces to control-panel
Postby Maxim » Wed Dec 07, 2016 2:17 pm
We have tested Onlyoffice Enterprise Edition on CentOS. We had the same issue with Control Panel. The problem was solved when we disabled firewall using the command:
systemctl disable firewall
Please try this solution on your server.
Also you can try the following instructions:
1. Forced clean cache of the browser
2. Find the container with Control Panel (use 'docker ps -a') and restart monoserve and nginx
docker attach "container_id"
service monoserve restart
service monoserve2 restart
service nginx restart
3. Check loading pages of the portal from the container with Control Panel and from the host
wget http://dnsnameonlyoffice/
4. Ping Control Panel name from the container with Community Server.
ping "name_of_CP_container"
5. Clean cache of redis from the container with Control Panel and restart it
sudo redis-cli flushall
sudo service redis-server restart
6. Check the license
7. If https is used, check the correctness of the certificate.
8. Perform a clean installation on a clean operating system (reinstall your OS and install docker and Onlyoffice) using the script. See instruction here:
Feel free to contact us here if you will have any troubles or suggestions.
Postby dsi-lille » Wed Dec 07, 2016 3:00 pm
thanks for your quick answer.
OnlyOffice is installed on a Debian, firewall doesn't exist.
I tested all your solution, the issue still remain.
Except for the clean install, because I'm not sure how a clean install could solve this issue. Before all those updates, Control Panel was working.
I take a look at control panel logs, and i notice this error that appears after the update:
2016-12-07 15:35:22,525 ERROR [Threadpool worker] ASC.Api - Error: NameResolutionFailure
System.Net.WebException: Error: NameResolutionFailure
at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <bd46d4d4f7964dfa9beea098499ab597>:0
at System.Net.HttpWebRequest.GetResponse () [0x0000e] in <bd46d4d4f7964dfa9beea098499ab597>:0
at RestSharp.Http.GetRawResponse (System.Net.HttpWebRequest request) [0x00000] in <79bf2ecafc5543eda8ebe5f2eedb6e19>:0
Thanks again,
Yoann
dsi-lille
Postby Maxim » Thu Dec 08, 2016 11:02 am
Unfortunately there was a bug in updating process.
Please update your system again using the script with parameter -u (not using Control panel). Don't forget to delete old installation script!
wget http://download.onlyoffice.com/install/ ... install.sh script and than run
bash enterprise-install.sh -u
Not to lose data you must have mapped folders.
Postby dsi-lille » Thu Dec 08, 2016 2:43 pm
Thanks, it works.
It was also a problem from our side.
We launch onlyoffice containers with a custom script and we didn't add all the new parameters with the docker run command (--net onlyoffice, -e DOCUMENT_SERVER_PORT_80_TCP_ADDR ...).
I add all the new parameters and it's works now !
Thanks for your help, we will check our launch script more often now !
Yoann.
dsi-lille
