It's possible to change a password with LDAP authentication
Postby dsi-lille » Mon Nov 14, 2016 3:54 pm
I use LDAP authentication in my portal.
When i perform the action to change my password, a notification say that this is forbidden because we use LDAP authentication.
Despite this notification, i still get an email with a link for changing my password and it works !
I can login with my ldap password and the new password.
Could you, please, fix this ?
Thanks a lot !
Yoann.
dsi-lille
Re: It's possible to change a password with LDAP authenticat
Postby Maxim » Tue Nov 15, 2016 8:38 am
Thank you for your feedback!
We will update LDAP and fix the problem in future release.
