Server:Cant Access Network
Postby bdearlove » Thu Oct 06, 2016 2:41 pm
Good Day All,
We have the enterprise version which has been running several months with no issue.
We are trying to back up by copying the /apps folder from the server to a mounted drive, unfortunately the server cannot access, can't even ping devices on the same network.
OnlyOffice is working and external devices can ping and ssh the server, only going out.
My familiarity with Ubuntu is limited, wondering if anyone has seen this issue or the cause? I am assuming some docker routing issues?
Thanks.
bdearlove
Re: Server:Cant Access Network
Postby Eugenie » Fri Oct 07, 2016 2:13 pm
If you use Enterprise Edition, please use Control Panel for backups:
http://helpcenter.onlyoffice.com/server ... store.aspx
If you have any other questions, please specify them.
Eugenie
