Rows are deleted when I filter my data in a spreadsheet
Postby dsi-lille » Mon Jul 11, 2016 2:08 pm
with a simple spreadsheet (like two columns with 1000 lines of data), I use a filter on both column (A and B) and this filter options : "Sort Lowest to Highest" or "Sort Highest to Lowest".
If i close the editor and i re-open the spreadsheet some rows are deleted.
We use the docker version with the latest version for the community (8.9.0.118) and document server (4.0.0.9).
Can you help me ?
Thanks,
Yoann
dsi-lille
Re: Rows are deleted when I filter my data in a spreadsheet
Postby Dean » Mon Jul 18, 2016 9:34 am
Could you please send us a screenshot of the issue or the link to the spreadsheet (for external users)?
Postby dsi-lille » Mon Jul 18, 2016 1:10 pm
thanks for your answer.
The link : http://docker-onlyoffice.ac-lille.fr/pr ... z0_Ijc3Ig2
Of you want to reproduce the bug, you have to follow this steps :
- add a filter on both colum (A and B)
- use "Sort Lowest to Highest" or "Sort Highest to Lowest" options
- close the editor
- and re-open the spreadsheet
thanks again,
Yoann.
dsi-lille
Postby Dean » Thu Jul 21, 2016 12:55 pm
Unfortunately the server by link is unreachable. Please check the link.
Postby dsi-lille » Thu Sep 15, 2016 9:26 am
I tried 2 times to answer at this post.
my answers are not displayed why ???
dsi-lille
Postby dsi-lille » Thu Sep 15, 2016 9:27 am
Anyway, the link should work now.
Thanks for your help,
Yoann.
dsi-lille
Postby Eugenie » Fri Sep 16, 2016 2:17 pm
Yoann, we released a new version now, so please first of all, update your installation as it should solve the issue.
Eugenie
Postby dsi-lille » Mon Sep 19, 2016 7:48 am
The problem remain with Document Server V4.1.0.308
Thanks,
Yoann
dsi-lille
Postby Eugenie » Tue Sep 20, 2016 3:19 pm
Yoann,
The rows are not deleted, they are sorted in the lower part of the spreadsheet. To avoid the issue you need to merge columns in formated table or autofilter
Eugenie
Postby dsi-lille » Thu Sep 22, 2016 2:22 pm
Eugenie,
i don't get it.
i create a spredsheet with 300 rows in column A with value from 1 to 300
i add a filter on this column with "Sort Highest to Lowest" option
the filter works, my value are sorted from 300 to 1 and i still have 300 rows
i close the spreadsheet, wait a little and re-open it
result : they remains only 257 rows (value from 300 to 45). (see https://escola.ac-lille.fr/products/fil ... z0_Ijc3Ig2)
If i search in the spredsheet for the value between 44 and 1 : no result (except for the value 2, row 300)
conclusion : some rows are deleted
Yoann
dsi-lille
Next
