Sudden Error while opening or viewing documents
Postby francgiovanni07 » Thu Aug 02, 2018 10:04 pm
The servers were working fine and then all of a sudden it began displaying this error message on all the document sections
Expression #1 of SELECT list is not in GROUP BY clause and contains nonaggregated column 'onlyoffice.d.folder_type' which is not functionally dependent on columns in GROUP BY clause; this is incompatible with sql_mode=only_full_group_by
almost all other functionality is still working i think.
please help Thank you
francgiovanni07
Re: Sudden Error while opening or viewing documents
Postby Maxim » Fri Aug 03, 2018 7:23 am
Hello francgiovanni07!
1. Specify please what instruction you followed to install Onlyoffice. Is it docker or RPM/DEB?
2. "began displaying this error message on all the document sections" - attach screenshot please.
3. What is the version of Onlyoffice or Document server?
Postby francgiovanni07 » Fri Aug 03, 2018 4:06 pm
Hi Maxim,
Thank you for your prompt response.
1)This onlyoffice is installed on ubuntu directly with nginx.(rpm/deb)
2)Screenshots attached
3)Version Version 9.5.4.553
Maxim wrote:Hello francgiovanni07!
ADDITIONAL EMAIL ERROR
SCREENSHOT OF ERROR FROM DOCUMENT SECTION
francgiovanni07
Postby Maxim » Tue Aug 07, 2018 11:50 am
You need to change MySQL config - see here. It happens when database was not installed by our installation script with needed parameters but was used existed MySQL database.
Postby francgiovanni07 » Sun Aug 19, 2018 3:21 pm
Maxim wrote:Hello!
Hi Maxim,
Where can I find this file on the linux installation?
Thank You!
francgiovanni07
Postby Maxim » Tue Aug 21, 2018 1:50 pm
Hello francgiovanni07 !
I suppose it should be /etc/mysql/conf.d
Postby francgiovanni07 » Tue Sep 25, 2018 4:07 am
Unable to locate it.
I am still getting this error. Please assist in rectifying the prob.
Thank you.
francgiovanni07
