LDAP integration - users can't log in
Postby Potleezus » Thu Jun 28, 2018 11:21 am
I'm using version 9.6 Enterprise. I used the docker version to install. My ldap users and groups are syncing correctly, however they can't log in. Only the local account I created during install can log in. Please help.
Potleezus
Re: LDAP integration - users can't log in
Postby Maxim » Fri Jun 29, 2018 8:07 am
Hello Potleezus!
Do you see LDAP users in 'People'?
....however they can't log in
Do they get any error? Do they try to log in using email?
Postby Potleezus » Fri Jun 29, 2018 9:51 am
Hi Maxim,
Thanks for getting back to me.
1. Yes I can see my ldap users.
2. The error is: Invalid username or password
I've made sure that I'm using the correct username/password combination. We're using version 9.6.1
Potleezus
Postby Potleezus » Fri Jun 29, 2018 9:53 am
Just to add to the answer: Yes they are logging in using email.
Potleezus
Postby Potleezus » Fri Jun 29, 2018 12:20 pm
Hi Maxim,
I changed my time zone and disabled ldap groups then did a sync. I'm able to log in now. I need help with the groups. Every time I activate ldap groups in Onlyoffice, none of my ldap users can log in.
Potleezus
Postby Maxim » Mon Jul 02, 2018 12:37 pm
Hello Potleezus!
What about logs?
1. Enable extended logs
docker exec -it onlyoffice-community-server sed -i 's/<level value="WARN" \/>/<level value="ALL" \/>/g' /var/www/onlyoffice/WebStudio/web.log4net.config
docker exec -it onlyoffice-community-server service monoserve restart
2. See logs in /app/onlyoffice/CommunityServer/logs
3. i need your screenshot of LDAP settings
