HTTP 402 with latest update
Postby matthias_k » Mon Apr 09, 2018 8:56 am
we tried to update our enterprise server on saturday to the latest version and now are getting a 402 response from our installation.
I have seen here (viewtopic.php?f=31&t=10222&p=15185&hilit=402#p15185) that this could maybe be solved by support quickly so I would like to adress it here (support ticket has already been submitted) as we got no response since saturday.
Regards,
Matthias
matthias_k
Re: HTTP 402 with latest update
Postby Maxim » Tue Apr 10, 2018 8:27 am
Hello matthias_k!
If you have a paid license you should contact support@onlyoffice.com or register here and send us your request.
How? Using Control Panel?
What instruction you followed to install Onlyoffice? Is it docker, RPM/DEB or exe?
Postby matthias_k » Tue Apr 10, 2018 8:50 am
Maxim wrote:Hello matthias_k!
Hi Maxim,
thanks - support has already fixed this - Ticket # 1503: It seems that some outdated licencing info was in the DB. Support has deleted the entries and from there on everthing was fine. Maybe you could look into this, so it doesn't happen again.
Edit: Docker installation - upgrade with control panel.
Regards,
Matthias
matthias_k
