[Document Server] Mail merge
Postby dsi-lille » Tue Mar 13, 2018 9:28 am
In Document Server, is there a way to do a mail merge without setting up an account in the mail module ?
We already have a webmail and don't want to use the mail module.
Thanks for your answer,
Yoann
dsi-lille
Re: [Document Server] Mail merge
Postby Maxim » Wed Mar 14, 2018 8:06 am
Theoretically it's possible. It needs to load your addresses from your database. In Enterprise Edition we load addresses from community server's database.
MailMerge.7z
(30.53 KiB) Downloaded 13 times
If you use this config
ar docEditor = new DocsAPI.DocEditor("placeholder", {
    "document": {
    "editorConfig": {
        "mergeFolderUrl": "http://example.com/select-mailmerge-folder.html?title={title}&fileuri={fileuri}",
then for the pdf format, clicking on the Save button will open the iframe for the following address:
https://example.com/select-mailmerge-fo ... ument.docx
that is instead of {title} will be substituted Example Document Title.pdf and instead of {fileuri} will be substituted this (https://documentserver/url-to-merged-document.docx)
Postby dsi-lille » Wed Mar 14, 2018 10:10 am
Hello Maxim,
thanks for your detailed answer !
Seems a little bit complicated but i will take a look :)
Is there any plan to integrate this in the interface ?
Thanks,
Yoann
dsi-lille
Postby Maxim » Thu Mar 15, 2018 11:30 am
Hello Yoann!
Unfortunately i have no info to give you a precise answer.
