Problem with Documents 1.3 and Android 7.0
Postby dsi-lille » Wed Feb 21, 2018 2:52 pm
On Android 7.0, when we try to connect from Documents 1.3 to our portal we get this error :
This is due to a bug on Android 7.0 with SSL.
Android 7.0 only supports ONE elliptic curve: prime256v1 aka secp256r1 aka NIST P-256.
Replaced this line, in the nginx conf
ssl_ecdh_curve secp384r1;
by this line
ssl_ecdh_curve prime256v1;
resolve the issue.
Google fixed the problem in Android 7.1.
Source : https://stackoverflow.com/questions/391 ... roid-n-7-0 (see the best answer)
I hope this will help :)
Yoann.
dsi-lille
Re: Problem with Documents 1.3 and Android 7.0
Postby Maxim » Thu Feb 22, 2018 8:36 am
Hello Yoann!
Thank you for this info!
