SpreadSheet and formulas between multiples worksheets
Postby bevito » Mon Jan 15, 2018 7:47 pm
Some users tried to upload existing 'xlsx' files (tested on Microsoft Excel 2016 and LibreOffice Calc 5.2.7).
The files upload just fine, but It seems, that some features do not work (formulas between multiples worksheet)
I just wandered If it is possible to send you an 'xlsx' exemple file to see if OnlyOffice can manage thoses formulas ?
Best regards.
bevito
Re: SpreadSheet and formulas between multiples worksheets
Postby Maxim » Wed Jan 17, 2018 7:53 am
Hello bevito!
Onlyoffice doesn't support such functional yet. But we are working on it.
