[Community Server] WebDav and Nuxeo
Postby dsi-lille » Mon Jan 15, 2018 10:08 am
the original topic is here : viewtopic.php?f=3&t=6752
Please, read it before continue !
My mistake, i discovered that you had overwriting some methods of the SharpBox library.
Upgrading the library may not be the answer and could be lot of work for you.
So i debugged your version of sharpbox and i found why i have a null exception
The problem is here :
var resourceType = prop.Element(XName.Get("resourcetype", DavNamespace));
Nuxeo WebDav doesn't include resourcetype element in it's answer, so resourceType variable is null and with this line :
if (resourceType.Element(XName.Get("collection", DavNamespace)) != null)
We get a nice System.NullReferenceException: Object reference not set to an instance of an object
Could you, please, fix this ?
Thanks a lot !
Yoann
PS : The orignal sharpbox library works with the webdav of Nuxeo
dsi-lille
Re: [Community Server] WebDav and Nuxeo
Postby Maxim » Wed Jan 17, 2018 8:43 am
Hello Yaonn!
Great thanks for your feedback!
I have redirected this info to our developers.
We will but i cannot say when.
Postby dsi-lille » Wed Jan 17, 2018 9:34 am
Hello Maxim,
thanks for your answer !
Yoann.
dsi-lille
Postby Maxim » Wed Jan 17, 2018 1:10 pm
Hello Yoann!
Please specify your version Nuxeo Platform and server's OS.
We found out that due to this bug there is no possibility to connect Onlyoffice to Nuxeo Platform using WebDAV.
Postby dsi-lille » Wed Jan 17, 2018 1:40 pm
Hello Maxim,
We use Nuxeo 6.0 with all the hotfix.
This bug concern only Nuxeo 9.
Anyway, i used the source of your sharbox library (with all your modification) and i run a unit test with Microsoft Visual Studio.
Trust me, the problem is really located here ;)
Thanks,
Yoann
dsi-lille
Postby dsi-lille » Fri Mar 16, 2018 9:50 am
Hello Maxim,
any news about this ?
Thanks,
Yoann.
dsi-lille
Postby Maxim » Fri Mar 16, 2018 10:40 am
Hello Yoann!
Yes, but i cannot say when we are going to fix it. Developers are overloaded for now.
But i hope it will be fixed soon.
Postby dsi-lille » Fri Mar 16, 2018 1:56 pm
No problem.
Thanks for your answer !
Yoann
dsi-lille
Postby Maxim » Tue Jul 17, 2018 8:19 am
Hello dsi-lille!
We have fixed this issue in 10th Community Server version.
Postby dsi-lille » Tue Jul 17, 2018 8:27 am
Hello Maxim,
great news !
Thanks a lot :)
Yoann.
dsi-lille
