Controlpanel - Whitelabel
Postby cantabrico » Mon Dec 18, 2017 10:21 pm
Hello.
I had to reinstall OO EE on a new server, and I have a problem: The Control Panel does not have the option of Rebrandig.
The manual url does not work:
example.com/controlpanel/whitelabel
https://imgur.com/EqR6DCa
Control Panel is in version: 2.3.0.135
It was a new installation on a new server with an installation script.
Then I delete and re-create the container- did not solve the problem.
I've removed the container, data, and docker and started the script again - it did not help
The new Control Panel installation does not include the Rebranding option
Where could be the problem?
cantabrico
Re: Controlpanel - Whitelabel
Postby Maxim » Tue Dec 19, 2017 6:45 am
Hello cantabrico!
WhiteLabel option depends on licence you have. Please contact to your Onlyoffice sales manager and clarify what licence you bought.
