NextCloud integration and api.js
Postby bevito » Thu Nov 16, 2017 5:31 pm
I've upgraded yesterday, OnlyOffice app for NextCloud (version 1.1.6).
OnlyOffice integration in NextCloud stopped working since then.
In previous version of OnlyOffice, api.js file was accessible from https://server.fqdn/web-apps/apps/api/documents/api.js
In our OnlyOffice server, api.js is accessible form this URL : https://server.fqdn/ds-vpath/web-apps/a ... nts/api.js
Is there a way to configure this URL ?
OnlyOffice version :
Control Panel : 2.2.0.130
CommunityServer : 9.5.1.517
DocumentServer : 5.0.4.15
NextCloud version : 12.0.3
Thanks a lot for your advice.
bevito
Re: NextCloud integration and api.js
Postby Maxim » Fri Nov 17, 2017 8:40 am
Add to your URL /ds-vpath
[solved] Re: NextCloud integration and api.js
Postby bevito » Fri Nov 17, 2017 10:09 am
Thank you very much Maxim !
OnlyOffice integration works again.
bevito
Postby Maxim » Tue Nov 21, 2017 10:32 am
Hello bevito!
But i have to say that this way of using of Document Server (being a part of the Enterprise Edition) with Nextcloud will be disabled.
Postby bevito » Tue Nov 21, 2017 10:53 am
Hello Max,
Thank you very much for the information.
Do you know why this feature will be removed ?
When you said "being a part of Enterprise Edition". Does this mean, this will still be possible in "Community Edition" ?
Have a nice day.
bevito
